Hi guys, I need some advice.
How important are the approximately 1/4" plus or minus long plastic guides inside the plastic pushrod covers? I am building a kit that calls for them on the elevator and rudder pushrods at approximately 3 to 4" apart along the pushrods. The instructions indicate that they should be gllued with a small drop of CA glue if they are a little loose. If they are reasonably important, will someone tell me how in the dickens
do you get them on the wire pushrod? I even tried to heat them slightly, but they still will not go over the wire. Thanks for your help!
Jim
