ORIGINAL: crankpin
I just found this thread, everything see is good, or great. Plug in wing's on the classic birds, and wing adjuster's ? Certainly a plus. Are you making kit's, etc., on request ?
Crank
All the parts & fuselages that are shown in this thread are available. I will be adding many as time permits and my money.... to make all these molds. I am very close to cutting wing cores for any plane wanted. For those that I make fiberglass fuselages of I will be putting together kits with the fuselages wing pans etc. and the form cores, and plans. I am also in the process of getting all the bulkheads, motor mounts, etc. laser cut for the kits. Most of the kits are Classic Pattern planes that we have saved. Although I will also be doing some modern Pattern planes and a few Giant scale kits. I have built and designed dozens of planes and had major delays because of some special pipe, landing gear, canopy, or whatever has stop or slowed down my builds. I know for a fact that many have experienced the same frustration. I make canopies, pipes, Fiberglass parts and Fuselages, foam cores, and laser cut parts coming very soon. Did I miss anything?
My aim is to eliminate this problem by offering all of these items. As time allows. This is a hobby, although I probably spend far more time in it than most. If you have question about a plane or part you can email me or PM me.
