RCU Forums - View Single Post - Broken Elevator, Need some advises.
Old 01-20-2011 | 08:19 AM
jester_s1
Moderator
Default RE: Broken Elevator, Need some advises.
The CA glue joint will hold up fine if you pressed the two pieces together well and used enough glue. the worry would be the weakening of the wood adjacent to the joint from splintering. If you're worried about the strength, make a doubler to reinforce the joint an inch or so on either side.
