RCU Forums - View Single Post - Pull Pull setup
Old 01-20-2011 | 09:41 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: Pull Pull setup
The actual amount of tension is not all that important. All you need is enough to eliminate any free play while under load. Using too much tension will cause problems with hinges and servo bearings if the cables go directly to the servo arm.
