so,
i get this rtf cub from flysone that got more weights added to it than an ocean liner anchor (nose had three ounces, tail two, wings when opened up had all kinds od strange debris that could only be intended to be balance. ) i did fly it few times but never did get it to trim right. i decided to convert it with an old radian glider wing that i added by splicing the cub cente section and installed a thermos botle liner as the nose. looks like a turbo cub now. see the link of my first flight. i used the same balancing points as the cub came with. didnt need to do much re arranging of the esc, battery, except that i lengthened the leads of the esc so that it was in the cockpit. flys like a cub and a glider. put a folding prop on it also.
da!!!!!!!!!!!!!!
Read more:
http://www.rcuniverse.com/forum/m_10...#ixzz1BeJhL3D5
