RE: stiff pushrods - help!
I don't use those tube in tubes any more. When I did use them I would insert a music wire into the outer portion then glue the 'outer' tube to the fuse. When glue cured I would remove the music wire and then put the 'inner' tube and its connectors in place. This gives a very straight run to the control surface.
