RCU Forums - View Single Post - Pull Pull setup
Old 01-21-2011 | 11:53 AM
Rodney
Default RE: Pull Pull setup
Positive Ackerman is when the line NOT being pulled, goes slightly slack as the servo is moved off center. This can be achieved by having the cables attach points at the servo slightly aft of the pivot point on the servo or by having the attach points on the controlled surface arm slightly forward of the surfaces hinge line.
