RE: 12z help.
If you're using Futaba servos, they have an odd number of splines on the output shafts. If you can't quite get the output arms at 90 degrees, remove them and turn them 180 degrees. That allows them to line up.
If you're using non-Futaba servos, then you're stuck trying to get things lined up.
