ORIGINAL: wildnloose
Do u remember how much rpm you gained using the Evo muffler?? Also, what prop??
It is like night and day. The evo motor with the stock muffler has midrange problems. The evo tuned muffler cleaned that up and raised the rpms about 1500. I was using a 10x7 on my kaos but changed to a11x6 for the P7. You have to get the motor up on the rpms or it doesn't run good. I am using 15% fuel because there wasn't much gain with higher nitro . Get the engine/prop combo to turn at least 15000 and it should run good. Check out the evo60 threads in the glow motor section .
