RE: poor traction issue, suggestions please!
Hi you are siupposed to break in motors at low voltage 3v or less if you used 12V you probably buggered up the com and brushes worse than when you had the motors in the tank.
also if you want better traction try CA glueing a few rubber pads on some of the tracks that should give you a little more bite.
