RCU Forums - View Single Post - GMP'S GoldWing MX2 The Green Machine
Old 01-21-2011 | 07:18 PM
kerwin50
Default RE: GMP'S GoldWing MX2 The Green Machine
Now when I put the elev servo's in I had a bit of a problem drilling the holes for the servo's because I should of drilled them before I put the stab in.
I used GOTECK 5511's on the elev halves and once again they had perfect centering.
I also used GOTECK's supplied servo horn's saving some weight, yet still getting full deflection. these servo's also have great centering.
I elected to use the dual servo's option. It was really easy to set up with my Futaba 9C. I used the AILEVATOR function on the 2nd screen that uses channel 2 and 8
