RCU Forums - View Single Post - Electronic Kill Switch
Old 01-22-2011 | 01:00 PM
Rocketman_'s Avatar
Rocketman_
Default RE: Electronic Kill Switch
ORIGINAL: Rumble
I could see a modified electronic kill switch that used a mechanical relay.
It sounds like you're describing this little gem of a kill switch from rcats.com. There is a tiny relay inside that can be setup to be normally open or normally closed. I use it in the normally open configuration so that it opens and shuts off the ignition when I flip a transmitter switch or if the receiver power fails.
