RE: Hitec servos and Spektrum
Jim, i had that problem, but only on certain channels, in a futaba receiver. It turned out to be the signal voltage on some channels is lower than required for the 7955 servos. Newer servos can operate at lower signal voltages. Try plugging the servos into channel 1 and see if the problem goes away.
