RCU Forums - View Single Post - Plastic pushrod guides!
Old 01-22-2011 | 04:48 PM
tacx's Avatar
tacx
Default RE: Plastic pushrod guides!
Yes, Lnewqban is correct. They are intended to help the rod slide in the tube. They are a pain in the *****. I had them on a couple of planes I bought from another modeler, and when those planes needed rebuilds I did away with those slides. There are much better systems available. If you can keep your rods and tubes fairly staight you don't need the little slid guides.
