ORIGINAL: fougamagister
Hello,the Navigation Ligths Set is ready.It consist of 2 print board coupling the shape of navigation lights location in the wings, with 2 led high brightness SMD 1 Watt, 2 resistor calculated for a power supply of 7,2 Volts ( Li-po Battery suppling the PowerBbox, and a couple ow twisted pair wires for 120 cm. of lenght.RegardsLucianowww.flyunitedteam.net
Hi Luciano,
Although I do not own this plane, I like your ideas. The navigation light board is a brilliant one. The copper plan provides both welding tabs and head dissipation. Easy, quick and reliable. Well done.
May I ask you what resistors you're using to make the LED's compatible with 7,2V ?
Many thanks. Oli.
