RE: Start-up issues ...
The other problem you may have is that the low speed needle valve is to lean. Turn it counter clockwise about 1/8 turn. That richens the low end. If it is a new engine, and you have the manual, adjust both needle valves to the manuals spec's. I like to run my engines rich, and never to lean.
