RE: are these blades any good for cp pro?
Flew 2 packs of the 250 and 1 of the 450 just now in my front yard.
I'm having a couple of issues.
Concerning the 250: This has been plaguing me for a while. It seems like my pitch is way off or something. I mean, there were times that I was at just shy of full collective, and I was only hovering 4 ft off the ground. Even punching it just barely seems to affect it. Its really strange. This odd behavior started after a rebuild of a crash I had this summer and I had to replace of of the blade grips because the arm to the linkage rod was bent. I also lost the pinion, so no im running 15tooth rather then the stock 16.
If you guys recall, I had this same issue a few weeks ago and I found that I did have a goof in my radio setup. For some reason my throttle curve only went to like 80% rather than 100%. After fixing that, its better, but it still feels really off. I will go through my settings again, but if you guys can think of anything, please post.
Thanks!
