RE: T-6A Texan II 75-91 ARF build suggestions
Ok maiden video comming soon. Hint it was Awsome.. Bob the stearable arm and pin for the Eflit is garbage not ment for flying on Grass fields. bent after thte first flight so maiden was all i got today. the pin that you show is 10 times stronger than the one that comes withthe eflite. I have taken out the pin screw from the mechanicals that came withthe plane ( the ones that you are showing) and put them in to my eflite arm. the eflites are straong but this pin is ridiculas. this new set up is stonger but i am going to see if i can't find a better option her is the hybred part i made fro the to peices.
