ORIGINAL: FLAPHappy
You do what you feel is necceary. I question, why did you ask the question if you wanted advise? I gave you my opinion and only a suggestion.
In my limited experirence, the low end is too lean. Blow bubbles until you find out.
Hi FLAPHappy, yes I did ask for advise. And no offence intended, but no need to send me off blowing bubbles. I'd rather check the basics first and I think it is basic info that the low end should be adjusted only after the high end mixture is ok. If I still have the same issue after I check that that the basics are Ok, then I will see where LS / idle is closing it and counting how many turns. Then I could richen it to see the result.
