RCU Forums - View Single Post - Start-up issues ...
Old 01-24-2011 | 05:24 AM
millerhill's Avatar
millerhill
My Feedback: (19)
Default RE: Start-up issues ...
Definitely sounds like a fuel problem. Tank is too high/low or like the other poster said a problem with the fuel lines. Make sure you don't have your lines switched and that there are no breaks/cracks in them.
If your idle setting is way off, you may have problems starting. You should be good with factory settings at least to get started.
Steve
