ORIGINAL: BarracudaHockey
That sounds like fun!
Can I put floats on a chopper?
Sure !!...I've done it before...you just have to be on the tail rotor when you spool it up...otherwise it will immediately start spinning in the water until you get enough RPM's on the tail rotor for the gyro to correct it....it's a little scary the first time...
