RCU Forums - View Single Post - new redcat mini plane!
Old 01-24-2011 | 10:42 AM
nitrosportsandrunner's Avatar
Default RE: new redcat mini plane!
ORIGINAL: formula87
ORIGINAL: nitrosportsandrunner
i sorta flown a jet tiger(sold also under another name, same plane) into the ground!
not a reflection on the plane so much as on my skilz. EDFs are harder to fly than normal prop planes.
i wouldnt hesitate to buy the P51 mustang. the specs look good and i like the details. its not a beginners plane tho. maybe a good 2nd plane.
You say into the ground ..............I have read the Jetiger is nose heavy with the wrong battery. I have a huge field to play in behind work so I will take my timeand use the flight sim also........... looks like it flys well on the youtube vids http://www.youtube.com/watch?v=28H5mN8psgg ...
it is very possible that i had the CG wrong, causing the crashes. the thing is the nose section is thin, and broke in half. i repaired it once, then it broke further back on the nose. not worth trying to repair again.
i have a artectech funjet(pusher prop) that has a simillar shape. but the nose section is much wider and stronger. i like it much better. but in the right hands the jettiger is wicked fast!
