RCU Forums - View Single Post - TT .46 Pro problem.
Old 01-24-2011 | 08:48 PM
  #48
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: TT .46 Pro problem.
ORIGINAL: proptop
Rear is a 6902 (28 x 15 x 7 mm )
Front is an R6 (7/8 x 3/8 x 9/32'' )
Thanks for all of your help, guys.. I appreciate it. As far as those bearings go - is one really SAE and one Metric? Aren't both bearings usually metric? I totally believe those to be correct, I just find it a little odd that one's metric and the other isnt.
I'll order those up and pop 'em in. I can use the 300°F oven trick to swap bearings on an aircraft engine, right?
