RCU Forums - View Single Post - TT .46 Pro problem.
Old 01-24-2011 | 09:39 PM
  #51
proptop's Avatar
proptop
My Feedback: (8)
Default RE: TT .46 Pro problem.
ORIGINAL: 1QwkSport2.5r
ORIGINAL: proptop
Rear is a 6902 (28 x 15 x 7 mm )
Front is an R6 (7/8 x 3/8 x 9/32'' )
Thanks for all of your help, guys.. I appreciate it. As far as those bearings go - is one really SAE and one Metric? Aren't both bearings usually metric? I totally believe those to be correct, I just find it a little odd that one's metric and the other isnt.
I'll order those up and pop 'em in. I can use the 300°F oven trick to swap bearings on an aircraft engine, right?
Yeah...kinda screwy, huh?!
The TT .40 and .46 and the O.S. .40, .46, and .55 and Evo .40, .46, .52, Magnums, etc. all use those same two bearings...
If you've successfully changed bearings in your car / truck engines, then it should be easy for ya...
I use heat and cold (toaster oven or propane torch...and the freezer ) the bearings will literally fall into place.
