RE: FIX THE IMAGE LINKS D HEADS
I found something that seems to help. It seems something with the cookies is what the problem is. If I log out then log in again I can get photos to upload. I will also post, hit ok, then go back and edit to add photos. Using the multi file upload option seems to work better then the regular upload. I am with the others that usually post here to go to other forums to post my build threads there. It's a lot of work to type it all out so people can understand it then when you go to upload the images it all goes poof! It has gotten better in the last 24 hours though. I was able to use both styles of uploading tonight so maybe the worst is behind us.
