ORIGINAL: captphil
I have an Earthquake 8E and want to know if there are any videos on how to ad gear oil to the diffs, or to access the diffs for shimmonmg?
Don't know if this is okay to post as this should be a locked threadif not delete.
http://www.rcuniverse.com/forum/m_10173683/tm.htm
This is a post on the vids I madeshimming the diffs but you may not need to shim them and with filling them just take out the 4 screws (have not done a vid on this I may well do one) just be easy on the screws.open up and becareful not to disturb the gears inside and fill almost all the way then put back together still easy on the screws.
