RCU Forums - View Single Post - 2 Stroke Double the power?
Old 01-25-2011 | 02:43 PM
proanti1's Avatar
proanti1
Default RE: 2 Stroke Double the power?
ORIGINAL: Justin B
ORIGINAL: Nitro Racer 18
Would you need a 60cc 4 stroke engine to match the power of a 30cc 2 stroke engine?
There are some interesting answers.
Technically, yes you would need double the displacement with a 4 stroke to equal the power potential of a 2 stroke. Every time a two stroke piston comes up in the cylinder it is a power stroke and it exhausts on the down stroke. A four stroke engine's piston goes up and down twice before a power stroke. So for 2 engines with the same displacement (2 vs 4 stroke) the 2 stroke will have twice as many power strokes as a 4 stroke. Four strokes make more torque sooner and can rev every bit as high as a two stroke. (think formula one engines) 2 strokes are lighter, have less moving parts and are easier to work on.
Not exactly, double the power strokes doesn't mean double the power. Two strokes have a ton more compression to fight against (on the up stroke, as well as the down stroke), four strokes have a heavier flywheel (or crank) that can hold a lot of momentum, which is one of the reasons they are so torquey.
