ORIGINAL: Heatseeker_Hill
i want to hook the ailerons into the flap on a current model and wondered if anyone had any experience of this ie if the flap lowers 45 degrees should the ailerons lift 45 or should i take into acound the surface areas of the ailerons in comparison to the flap and lower the movement accordingly.
On my bandit I use 1/2" of crow and on the king cat I use 1" both work well. Depending on the plane you might need to mix up or down elevator. Good luck Dan Avilla
