I have had planes tip stall but recover?? So far I haven't figured it out. I'm usually going too slow on a landing and a few inches or feet off the ground. The only in air stall I have had was with a bipe and when it stalled I had a hundred feet or so, it went into a hard, fast snapping spin and as hard as I tried noting helped. Another friend with the same plane had the same thing happen, too slow, too low and turning into too sharp of an angle. What caused the stall I know, my bad. What I could have done about it?? Maybe being higher so I had some time to work on the problem.
