RCU Forums - View Single Post - 2 Stroke Double the power?
Old 01-25-2011 | 08:13 PM
sloppyG
Default RE: 2 Stroke Double the power?
ORIGINAL: savagecommander
4 strokes dont have any more torque than 2 strokes. an engine reaches torque peak when the cylinder is filled the best, and it happens at a lower rpm in 4's than 2's. and compression ratio has no effect on power lost- it makes up what it loses.
and yes, if an engine produces twice as many power strokes in a given time, it will produce twice as much power-and burn twice as much fuel. lets not try and clog the thread about who's smarter, or has been modifying engines longer or whatever- its not a contest.
in a rough sense sure, that's a good approximation but the two stroke doesn't fill and empty the cylinders as efficiently as a 4 stroke so you can't burn twice the fuel (because you're not getting twice the oxygen into the cylinder)
depending on how rough we're being you are correct
