ORIGINAL: mauryr
After the gas ignited properly, she spun up to pre-heating and then shut down giving me a ''bad start'' error. This happened 2 or 3 times then the engine actually started properly.
It then ran flawlessly just like the one I tested ''on the road'' so I shut it down to straighten out the startup issues. Cooling was also perfect.
Hi
Did you prime the fuelsystem before you attempted to start the turbine? If not, this is normal.
Christian
