RCU Forums - View Single Post - Problems finding the C of G
Old 08-07-2003 | 03:19 PM
jacs's Avatar
jacs
Default Problems finding the C of G
Okay measured with a incidence meter right now and stab is 3 cm higher and after aligning wing to zero I moved to stab and that one is also 0 degrees. Have to make a real check with a line from engine to stab as thrust line and go from there.
Made a line from engine to stab and level the plan with that now I have +2 degrees on stab and +1.5 degrees on wing.
