RCU Forums - View Single Post - PST REVISION BUILD
Old 01-27-2011 | 05:01 PM
mavrick
Default RE: PST REVISION BUILD
HI Skywarrior
I got mine last November but have not been rushing the build,I have a Reaction X that I have been having a ball with for the last 18 Months. Back to the ReVision I am going to remove a little from the bottom of the fin back about 20 mm from the LE and shape a piece of Ally strip and Hysol in place then drill a hole through the Ally and top of Fuzz to find the right place then Hysol a piece of 6mm ply drill it to take a blind nut and you can use a cap head bolt, eazy fix.I have 2XA123X2200 Batteries up front, the wings are finished and I have most of the front completed. We are in the middle of summer here this week it has been high 30's low 40's not good weather for Jets. One thing I haven't worked out yet is how to fit the speed brake I haven't got any offset hinges that are strong enough, so I will try a few things I think I might be going to have trouble with the leeding edge binding when it is deployed. I have never used a speed brake before I was going to put it on the second stage of flaps but have decided to use it on another switch to start with . Keep in touch it is good to come up with new ideas
Best Regard
Mav
