ORIGINAL: twobnvd
I let the batter charge for about 30 min on the twin peak charger. It is the stock batter. I was also reffering to the Aftershock on the twin shock setup. These are brand new trucks and this was the first run. It studders the whole time. I was reading as much as possible but dont see anthing that would be the cause except for the batter not being charged all the way I was thiniing about tring one of the earthquakes lipos to see if it still does it. An help is greatl appreciated. Thanks guys!!
Matt
Nitro sport will that cable work for both the caldera and the earthquake?
caldera only. there is a program card for the ezrun 80amp ESC in the earthquake. youll have to look on ebay or i think urchobby.com has it?
it very odd that you got 2 new trucks that do the same problem. does the steering act up at all?
if you could post a vid on youtube and provide a link that would help.
i assume you already looked at the wires connecting the motor to the ESC and made sure they are plugged in tight.
so, the earthquake studdered as well....running the stock lipos?
also, check the gear mess of the motor pinions to the spur gear. too tight may cause the issue.
