RCU Forums - View Single Post - Making a universal timing bracket
Old 01-28-2011 | 08:18 AM
BadAzzMaxx
Default Making a universal timing bracket
Here is a good method to make a universal timing bracket using Rcexl ignition
It can be used with most any engines that has a round front crankcase from 1” to 1 ¾” with out having to drill and tap holes for threads.
3W- DA- ZDZ or if you are converting a chainsaw or weed whacker engine.
All it takes is a 5/16 stainless steel hose clamp, some heat shrink and Rcexl ignition with sensor and sensor bracket.
Check to get the polarity right and install the sensor in the bracket.
Install it on the engine, Set engine up for 28 deg before top dead center, Hook up battery and plug to the ignition and rotate the clamp counter clock wise from the front of the engine until you see a spark, Tighten the clamp with a ¼” nut driver and you are ready to go.
Milton
ID:	1554537   Click image for larger version
