RCU Forums - View Single Post - GP Super Stearman
Old 01-28-2011 | 10:20 AM
  #1684
Shubova
My Feedback: (9)
Default RE: GP Super Stearman
phakur,
Sorry about the bad link to page 54...what happened is I put a period at the end of the link, after the htm. So that is why it doesn't work.
Here it is again http://www.rcuniverse.com/forum/m_17...54/key_/tm.htm (no period)
Or as n6iap said you can just use the page finder.
The things I like about my set up is it is clean with only one wire out of the top wing. I rapped the wire with white electrical tape and used a white zip tie to secured the wire to the cabana so you barely notice it is there. And you don't have to use separate channels.
I have a friend, an old timer, who has built and flown models for many years. He once told me "The less adjustments you do with your radio the better off you will be". So that is what I do with all my planes. I use the KISS method when building a plane.
The adjustments are in the linkage and I didn’t have any problems doing it that way. You just have to make sure your adjustments are adequately secured. Also if you ever lose the radio settings, which I have done, you don't have to start all over.
But as I always you do what you think is best for you. What ever you do I can tell you from my experience your in for some real excitement flying this bi plane.
For those of you who don't know what KISS means…Keep It Simple Stupid.
Good Luck,
Shubova
