RE: Tornado S30 What happened???
for the wheels not going backwards, mine did that also my gear mesh was a little to tight, use the paper trick in the manual and that will fix the gearing, for the not moving part my guess is that being the gears not set wright you may have killed the clutch bell already, i have heard of these burning up fast before. im not positive on this but if everything else looks good i would look towards the clutch.
