RCU Forums - View Single Post - if you need a filler for foam...
Old 08-06-2003 | 02:27 PM
FLYBOY's Avatar
FLYBOY
Default if you need a filler for foam...
If you just need a little, your better off with red devil spackle compound, it has no weight and sands easy, if you need a lot, glue in another piece of foam and sand it smooth. Any glue you use is stronger than the foam. You wan to keep from making it heavy.
