RE: poor traction issue, suggestions please!
philipat, on my HL bulldog i removed the smoker because i wasnt very impressed with it. i used the plug for the smokder and connected it to a 1" 5 volt fan and mounted the fan onto my multi control unit for cooling. i also left the switch for the smokker connected so i can turn the fan off and on simply by flipping the switch. so if your not using your smoker then that is always an option you could use
