RCU Forums - View Single Post - What Do You Think
Old 01-29-2011 | 05:49 AM
ameyam
Default RE: What Do You Think
I was thinking of the same. However, if you look at it, the 75AX weighs more (only slightly- about 2oz or so) as compared to the FS91SII. So it may be a good idea to go for the 95AX then. Then when you look back, the wing-loading now is very high for 3D. After much deliberation, I gave up on this plane-engine thought and bought a Funtana 125 for the 120AX I already have.
For the record, I went down this route on my Topstar 60- it is the same airplane as the H9 Frenzy 60, ucd-60, Flip3D etc. I started with the 75AX and then moved to the FS91SII when I had engine problems. Now I am beginning to think the 75AX was better for that airplane
Ameyam
