RE: Pre-Flight Needs to Include Battery Load Test
Another system I use for checking battery voltage is the Dynamite system from Horizon Hobby. This puts a load on the battery, which its better to check with a load, and it gives voltage for "under load", because a standard volt meter may give the voltage with no load, and the battery may be close to dead, but still give a high voltage.
Jason
