Maybe the post below had something to do with the problem.<hr />BEWARE! I just found out that you should not connect your engine kill switch to the power lead on the ignition, but it should be connected to the hall sensor lead from the ignition. I tried connecting to the power lead and all the wiring got red hot in a few seconds, fortunately I unhooked the battery in time before it all melted down.
