RCU Forums - View Single Post - Da-Ja-Vu Build thread
Old 01-29-2011 | 10:26 PM
toddblose's Avatar
toddblose
My Feedback: (10)
Default RE: Da-Ja-Vu Build thread
Thanks Dean
Next set at this time will be the wheel paints. I under stand that there are many ways of mount the paints but this is very easy
and holds up great. First I will drill a 4-40 clearance hole in the paints. I will use a T shaped 1/8 light play and glue into place using
CA and some clamps. Next drill the same size hole in the gear and a clearance hole for a servo mounting screw 1/4 in straight up
from the axle hole. Next I will mount the both paints using the axle and axle screw only. Then I will set the plane on the gear and paints
on a flat surface and set the plane to 0. Once the plane is at 0 I will drill the hole into the paints for the servo screw. Then I put the servo screw
in and tighten. Flip the plane back over and remove the axles only, then cut the servo screw ( so it does not hit the wheel) then put CA on the screw then around where the axle goes. This will strength the wood so the axle will not collapse the wood. Then put the wheel on the axle and use some loctite and install the axle and wheel.
Axles NMPAXLEFGL from Central Hobbies
Servo screws CHMSMS100 from Central Hobbies
ID:	1555557   Click image for larger version
ID:	1555558   Click image for larger version
ID:	1555559   Click image for larger version
ID:	1555560   Click image for larger version
ID:	1555561   Click image for larger version
ID:	1555562   Click image for larger version
ID:	1555563   Click image for larger version
