RE: Install Asiatam Recoil in Panzer 3
I installed one in my panzer IV F2 ....I forgot to read the part where it says you need the Asiatam gun for the system to work ; so I installed the unit using my already painted air-soft gun ....
It's never a perfect fit when you put those in and takes some fine tuning ; but that's the fun part of the hobby ...
Get rid of the resistor ; the recoil motor needs all its power to push the gun at its initial place ....
If you have to pull on the gun to be able to fire again ; something is preventing the gun to sit in its place ...Check for the clearance between the inside of the gun mantlet and the Asiatam bracket holding the gun ; I had problems with that ....
Good luck and keep us posted ....
