RCU Forums - View Single Post - Gilbert .11
Thread: Gilbert .11
Old 01-30-2011 | 06:08 PM
dieselbloke
Default RE: Gilbert .11
<![if gte mso 9]><xml><w:worddocument><w:view></w:view><w:browserlevel></w:browserlevel></w:worddocument></xml><![endif]><![if gte mso 9]><xml><w:latentstyles deflockedstate="false" latentstylecount="156"></w:latentstyles></xml><![endif]><![if gte mso 10]><style type="text/css"> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0in 5.4pt 0in 5.4pt;mso-para-margin:0in;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style><![endif]><![if gte mso 9]><xml><o:shapedefaults v:ext="edit" spidmax="1026"></o:shapedefaults></xml><![endif]><![if gte mso 9]><xml><o:shapelayout v:ext="edit"><o:idmap v:ext="edit" data="1"></o:idmap></o:shapelayout></xml><![endif]><p class="MsoNormal">I've never really understood the compulsion to dieselize motors just for it's own sake. Some glows are rugged enough to make good diesels, most including the rather lightly constructed examples from the fifties and sixties aren&rsquo;t.
A good rule of thumb is how does the glow run on 30% nitro? If it can survive that it will probably hold together as a diesel.
I'd guess that this one won't, and what&rsquo;s the point anyway. There are lots of fine small diesels available from Ebay.
R</p>
