RCU Forums - View Single Post - Wing Hinges Sag
Thread: Wing Hinges Sag
Old 08-06-2003 | 06:15 PM
Highlander
Default Wing Hinges Sag
NC
Its not a good thing ! The wide gap or the sagging hinge! If it was mine I would redo them,
of course you could try and fly it and see what problems are evident from it, could get some flutter in that aileron ? could be a problem in trim as that tip will probly travel farther than the rest of the aileron.
just really depends on how far out it is ? if its a slight amount you may not see very much trouble from it at low speeds but as speed increases so will the effects .
Highlander
