RCU Forums - View Single Post - Da-Ja-Vu Build thread
Old 01-31-2011 | 09:02 PM
toddblose's Avatar
toddblose
My Feedback: (10)
Default RE: Da-Ja-Vu Build thread
Mounting the aileron servos is next. The wings come covered so the servo hole needs to be cut out. I always use a new blade and cut the hole out and leave 3/16 inch all the way around and iron the excess into the servo hole. I then cut the rails (using 1/4 x 3/8 spruce) and pre fit all rails. Then I will use the calipers to set the depth of the rails. Once the rails are glued in you can mount the servo. Since all of the servo leads are always too short you will need to use an extension. I always use heat shrink to make sure that they don't come unplugged. This plane has SFG's so the slots are pre cut but the covering and or paint will need to be removed. On the painted wing you can use some sand paper to clean the edges. Then just slide the SFG into place and CA.
ID:	1556674   Click image for larger version
ID:	1556675   Click image for larger version
ID:	1556676   Click image for larger version
ID:	1556677   Click image for larger version
ID:	1556678   Click image for larger version
ID:	1556679   Click image for larger version
ID:	1556680   Click image for larger version
ID:	1556682   Click image for larger version
ID:	1556683   Click image for larger version
ID:	1556684   Click image for larger version
