RE: PST REVISION BUILD
David,
Thank you for the info and I shall also do this now ,just in case !
I enclose a shot of my elevator servo solution with ceramic blanket. I hope the extra few grams will give me a large penalty up the front end when it comes to balancing.
I will cover the servos in ali tape as well.
I suspect your solution is better and maybe lighter but I cant figure it out from the description.
Hey 40 deg is hot and I am not sure I envy you quite that much heat. I only experienced 42' once in Ethiopia towards the Danakil depression and once is enough for a fair skinned guy like me I think.
Best regards
David
