RCU Forums - View Single Post - Convert old Sequel pattern ship to electric?
Old 02-01-2011 | 05:56 AM
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: Convert old Sequel pattern ship to electric?
Now the exciting moment came as the motor can be mounted.
FIrst, I measure the depth of the motor from the prop washer to the rear. That become the location of the firewall on fuse. I then draw one line at either side of the fuse. I allocated points on those two lines about half inch between consequent two points. Setting the fuse on the table and put a ruler against the fuse side, I measured the distance between the straight edge of the rule and each point allocated. The measures allowed me to draw a firewall template on paper. I was able to get a very precise template in one step.
I decided to use Himax F3A 6330 motor as it was just introduced to the market and has the same mounting pattern as other more popular outer runner. I figured I can always go with a better motor later on.
Shown below are the installed motor mount / firewall made from 3mm aircraft plywood, and Himax 6300 installed on the new mount.
ID:	1556778   Click image for larger version
ID:	1556779   Click image for larger version
ID:	1556780   Click image for larger version
