RCU Forums - View Single Post - Sig Wonder Build
Old 02-01-2011 | 08:26 AM
  #73
dash008
Default RE: Sig Wonder Build
Did the cowl last night. a lot of aligning and taking the engine on and off a number of times. I'm still liking that mount. The instructions called for sanding it all down with the engine installed but I did not want to do that so I marked the location of the spinner on the ply spacer ring with a pencil and sanded it down with the engine off. This went pretty fast with 80 grit sandpaper.
I know I dorked up the holes for the fuel lines. The drill bit slipped. I'll fix that with covering and white silicone later. You'll never see how ugly it looks.
ID:	1556794   Click image for larger version
ID:	1556795   Click image for larger version
ID:	1556796   Click image for larger version
